I was considering purchasing this product but had a couple of questions I would like to have answered before doing so.
- Is this considered an MOS (metallic oxide semiconductor) sensor?
- If so, what metal oxide is used for this sensor?
- How sensitive is this sensor to various environmental factors such as temperature and pressure?
- How would one calibrate this sensor effectively? Are there ranges of output values to expect for certain ppm’s of CH4?
Thank you!
