I’m using a I2C Shield for WiPy2 & LoPy with a LoPy4. I’m communicating with sensors over the I2C interface. The documentation states:
“The I2C port 5V is controlled by a GPIO pin and can be turned on all the time depending on jumper selection. If you are using this with a battery then you can turn on and off the I2C port according to your needs.”
Thats for the reply.
It appears that the solder bridge labeled GP32 configures whether GP32 (P19) can enable and disable power. There are three solder pads. Which pads should be soldered together to allow the LoPy to turn off power the I2C interface?
