the product description of “16-Channel General Purpose SPDT Relay Controller with I2C Interface” mentions only 5V at the I2c port.
As my Teensy 3.6 is ONLY 3.3V, I wonder if there is a way to use the relay controller without switching to a Teensy 3.5 or introducing level shifters.
What happens if the I2C port of the relay board is run with 3.3V from the master? Are the SDA/SCL lines still 5V?
