We need to make (only 3!) I2C cables probably about 12’ long between these for a new building installation. It will be in 3/4" metal conduit so an existing connector we assume can’t be pulled through the conduit.
- MCP9600 K-Type Thermocouple I2C Mini Module
- Ethernet to I2C Converter
We see info suggesting we can use CAT5/6 and warning us to reduce data rate, that’s ok. See:
- https://store.ncd.io/product/i2c-interface-cable-nodelynk-connector-4-pin-male-molex-0705530003-wm4902-nd/
- I2C Communications Quick Start Guide - NCD.io
We see products and previous posts referring to a Molex connector, but it seems to be the PCB mount side. We need a connector that we attach to each end of the CAT5/6 (or other recommended cable) - essentially the same connector you use on your cables. (Note however this would be 22 gauge wires if we use CAT5).
Thanks for your help.
