I’ve plugged the MCP23008 , ADC121C021, and SHT25 into my Pi2 via the i2c-shield.
The MCP23008 is powered by it’s power adaptor.
The red power lights for each device comes on.
and on my Pi2 i have rasbian with node-red installed, the I2C communications have been enabled via the raspi-config
However with the following node-red flow to report the discovered I2C devices addresses :
[{“id”:“7a2e4ed3.4bba1”,“type”:“tab”,“label”:“Flow 1”,“disabled”:false,“info”:""},{“id”:“373d2416.edca24”,“type”:“inject”,“z”:“7a2e4ed3.4bba1”,“name”:"",“topic”:"",“payload”:"",“payloadType”:“date”,“repeat”:"",“crontab”:"",“once”:false,“onceDelay”:0.1,“x”:100,“y”:220,“wires”:[[“f3c122a1.aaa9a8”]]},{“id”:“556dd833.88f618”,“type”:“debug”,“z”:“7a2e4ed3.4bba1”,“name”:"",“active”:true,“tosidebar”:true,“console”:false,“tostatus”:false,“complete”:“false”,“x”:190,“y”:340,“wires”:[]},{“id”:“f3c122a1.aaa9a8”,“type”:“i2c scan”,“z”:“7a2e4ed3.4bba1”,“x”:140,“y”:280,“wires”:[[“556dd833.88f618”],[“556dd833.88f618”]]}]
This is the flow without the SHT25 attached:
https://i.imgur.com/NBUWhmZ.gifv
This is the same flow, with the SHT25 attached:
https://i.imgur.com/2JMOqih.gifv
Shouldn’t I expect to see the address 40 in that list ?
