import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# MPU-6000 address, 0x68(104)
# Select gyroscope configuration register, 0x1B(27)
# 0x18(24) Full scale range = 2000 dps
bus.write_byte_data(0x68, 0x1B, 0x18)
# Select accelerometer configuration register, 0x1C(28)
# 0x18(24) Full scale range = +/-16g
bus.write_byte_data(0x68, 0x1C, 0x18)
# Select power management register1, 0x6B(107)
# 0x01(01) PLL with xGyro reference
bus.write_byte_data(0x68, 0x6B, 0x0
Its in ±16g but and according to the datasheet 1 page 15, its AFS_SEL. So i just simply replace the bus.write_byte_data(0x68, 0x1C, 0x18) the ‘0x18’ into AFS_SEL = 0 and replace ‘0x18’ into FS_SEL = 0 for both accelerometer and gyro?
Acceleration in X-Axis : 932
Acceleration in Y-Axis : -108
Acceleration in Z-Axis : 15036
X-Axis of Rotation : -362
Y-Axis of Rotation : -40
Z-Axis of Rotation : -114
Data i get using bus.write_byte_data(0x68, 0x1C, 0x18)
Acceleration in X-Axis : 924
Acceleration in Y-Axis : -32
Acceleration in Z-Axis : 15072
X-Axis of Rotation : -335
Y-Axis of Rotation : -30
Z-Axis of Rotation : -95
And these are the data i get by using (0x68, 0x1C, 0x00)
Aren’t they almost the same?
