"id": "9576c84fc05fba48",
"type": "play audio",
"z": "c7f311b561d11f73",
"name": "",
"voice": "0",
"x": 1210,
"y": 1140,
"wires": []
"id": "59d6f528028e9030",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" battery warning\"\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 980,
"y": 1060,
"wires": [
"6ce686c110da4464",
"9576c84fc05fba48"
"id": "fcc79c5b85608fba",
"type": "switch",
"name": "Set temperature limits",
"property": "payload_data.battery",
"propertyType": "msg",
"rules": [
"t": "lt",
"v": "0",
"vt": "str"
"t": "gt",
"v": "2",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 720,
"y": 980,
"wires": [
"59d6f528028e9030"
"59d6f528028e9030"
"id": "6ce686c110da4464",
"type": "debug",
"name": "debug 47",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1220,
"y": 1080,
"wires": []
"id": "c9776bc6f8e1e143",
"type": "switch",
"name": "Limit to Type 80",
"property": "payload_type",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 480,
"y": 960,
"wires": [
"fcc79c5b85608fba"
"id": "62e6cca397d10a0a",
"type": "ncd-gateway-node",
"name": "",
"connection": "e69d0ec8c02da9b1",
"unknown_devices": false,
"outputs": 1,
"x": 170,
"y": 600,
"wires": [
"8786d56e7500f219",
"c9776bc6f8e1e143",
"b59f324404e127c6",
"fa92b63bfa0505ed",
"9ba3716add53a55e",
"148a32035db48ed2"
"id": "8786d56e7500f219",
"type": "switch",
"property": "payload.sensor_type",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 480,
"y": 720,
"wires": [
"3e57dace527138b2",
"7f9c386269e249e2",
"a96407ea593cbe8a"
"id": "b59f324404e127c6",
"type": "switch",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 460,
"y": 440,
"wires": [
"620598867c3564f1"
"id": "fa92b63bfa0505ed",
"type": "debug",
"name": "debug 48",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"x": 440,
"y": 320,
"wires": []
"id": "9ba3716add53a55e",
"type": "switch",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 100,
"y": 160,
"wires": [
"f1a8611ec698886c"
"id": "148a32035db48ed2",
"type": "switch",
"rules": [
"t": "eq",
"v": "80",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 480,
"y": 1080,
"wires": [
"57d8bca623128d14"
"id": "3e57dace527138b2",
"type": "switch",
"property": "payload.sensor_data.x_rms_ACC_G",
"rules": [
"t": "lte",
"v": "-5",
"vt": "str"
"t": "gte",
"v": "30",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 740,
"y": 720,
"wires": [
"732fb2bb4e6eaa80"
"732fb2bb4e6eaa80"
"id": "7f9c386269e249e2",
"type": "switch",
"property": "payload.sensor_data.y_rms_ACC_G",
"rules": [
"t": "lte",
"v": "-5",
"vt": "str"
"t": "gte",
"v": "30",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 740,
"y": 820,
"wires": [
"75bcc56541b2f87a"
"75bcc56541b2f87a"
"id": "a96407ea593cbe8a",
"type": "switch",
"property": "payload.sensor_data.z_rms_ACC_G",
"rules": [
"t": "lte",
"v": "-5",
"vt": "str"
"t": "gte",
"v": "30",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 740,
"y": 900,
"wires": [
"1e311fe9b4d37638"
"1e311fe9b4d37638"
"id": "620598867c3564f1",
"type": "switch",
"property": "payload.sensor_data.temperature",
"rules": [
"t": "lt",
"v": "0",
"vt": "str"
"t": "gt",
"v": "30",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 720,
"y": 380,
"wires": [
"4c7f33789ca7c3dd"
"4c7f33789ca7c3dd"
"id": "f1a8611ec698886c",
"type": "switch",
"rules": [
"t": "lt",
"v": "0",
"vt": "str"
"t": "gt",
"v": "20",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 380,
"y": 80,
"wires": [
"0981ef9f82b4f128"
"0981ef9f82b4f128"
"id": "57d8bca623128d14",
"type": "switch",
"rules": [
"t": "lte",
"v": "-5",
"vt": "str"
"t": "gte",
"v": "30",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 720,
"y": 1080,
"wires": [
"1fb67de8539a66ee"
"1fb67de8539a66ee"
"id": "732fb2bb4e6eaa80",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" x_rms_ACC_G warning\"\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1000,
"y": 720,
"wires": [
"c08bfffb2cfdd8b5",
"ce55fad01b0fdc81"
"id": "75bcc56541b2f87a",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" y_rms_ACC_G warning\"\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1000,
"y": 820,
"wires": [
"6f87d81ef73d57dc",
"1cdf22ca0bfa782c"
"id": "1e311fe9b4d37638",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" z_rms_ACC_G warning\"\t",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1000,
"y": 900,
"wires": [
"ea3ac57bc63bb859",
"be3d473f26b90abe"
"id": "4c7f33789ca7c3dd",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" 1D온도센서오류\"",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 940,
"y": 380,
"wires": [
"88a786641233d073",
"eab249c4c1bd0a77",
"93cc2b40ca04753f"
"id": "0981ef9f82b4f128",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "jsonata"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 600,
"y": 40,
"wires": [
"4a79585c9bca2479"
"id": "1fb67de8539a66ee",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"tot": "jsonata"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" y_rms_ACC_G warning\"",
"tot": "str"
"t": "set",
"p": "payload",
"pt": "msg",
"to": "\"Sensor \" & (msg.payload.addr) & \" z_rms_ACC_G warning\"",
"tot": "str"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 960,
"y": 1140,
"wires": [
"id": "c08bfffb2cfdd8b5",
"type": "debug",
"name": "debug 49",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1220,
"y": 640,
"wires": []
"id": "ce55fad01b0fdc81",
"name": "",
"voice": "0",
"x": 1250,
"y": 700,
"wires": []
"id": "6f87d81ef73d57dc",
"type": "debug",
"name": "debug 50",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1260,
"y": 780,
"wires": []
"id": "1cdf22ca0bfa782c",
"name": "",
"voice": "0",
"x": 1270,
"y": 840,
"wires": []
"id": "ea3ac57bc63bb859",
"type": "debug",
"name": "debug 51",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1240,
"y": 940,
"wires": []
"id": "be3d473f26b90abe",
"name": "",
"voice": "0",
"x": 1230,
"y": 1000,
"wires": []
"id": "88a786641233d073",
"name": "",
"voice": "0",
"x": 1230,
"y": 420,
"wires": []
"id": "eab249c4c1bd0a77",
"type": "debug",
"name": "debug 52",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1180,
"y": 360,
"wires": []
"id": "93cc2b40ca04753f",
"type": "ui_text_input",
"name": "",
"label": "",
"tooltip": "",
"group": "edb876bc2485de7b",
"order": 11,
"width": 0,
"height": 0,
"passthru": true,
"mode": "text",
"delay": 300,
"topic": "topic",
"topicType": "msg",
"x": 1260,
"y": 480,
"wires": [
"id": "4a79585c9bca2479",
"type": "trigger",
"name": "blink blue",
"op1": "colors.led.blue",
"op2": "colors.led.off",
"op1type": "global",
"op2type": "global",
"duration": "250",
"extend": false,
"overrideDelay": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 820,
"y": 60,
"wires": [
"e677e442b4934d9d"
"id": "e677e442b4934d9d",
"type": "ui_template",
"name": "",
"order": 1,
"width": "3",
"height": "3",
"format": "<style>\n.led {\n position:absolute;\n width: 50px;\n height: 50px;\n margin: auto;\n border-radius: 50%;\n}\n</style>\n\n<div><span class=\"led\" style=\"background-color: {{msg.payload}}; box-shadow: #000000BB 0 -1px 1px 0px, inset #000000AA 0 -1px 4px, {{msg.payload}} 0 3px 15px;\"></span></div>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": false,
"templateScope": "local",
"x": 1020,
"y": 60,
"wires": [
"d48d9add6d75dbe0"
"id": "bb5b6ebfeca18b38",
"type": "trigger",
"name": "blink red",
"op1": "colors.led.red",
"duration": "250",
"extend": false,
"units": "ms",
"reset": "",
"bytopic": "all",
"topic": "topic",
"outputs": 1,
"x": 820,
"y": 120,
"wires": [
"e677e442b4934d9d"
"id": "d48d9add6d75dbe0",
"type": "switch",
"name": "",
"property": "payload",
"rules": [
"t": "eq",
"v": "colors.led.blue",
"vt": "global"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1170,
"y": 60,
"wires": [
"b2944f95f5c0e52c"
"id": "b2944f95f5c0e52c",
"type": "delay",
"name": "",
"pauseType": "random",
"timeout": "300",
"timeoutUnits": "milliseconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "200",
"randomLast": "500",
"randomUnits": "milliseconds",
"drop": false,
"allowrate": false,
"outputs": 1,
"x": 680,
"y": 120,
"wires": [
"bb5b6ebfeca18b38"
"id": "e69d0ec8c02da9b1",
"type": "ncd-gateway-config",
"name": "",
"comm_type": "serial",
"ip_address": "",
"tcp_port": "2101",
"port": "COM3",
"baudRate": "115200",
"pan_id": "7fff",
"rssi": false
"id": "edb876bc2485de7b",
"type": "ui_group",
"name": "A-1",
"tab": "2b1876438ce56d83",
"order": 1,
"disp": true,
"width": 8,
"collapse": false
"id": "2b1876438ce56d83",
"type": "ui_tab",
"name": "Main SCREEN",
"icon": "dashboard",
"order": 2,
"disabled": false,
"hidden": false
Thank you. I’ll post the chords
Can I get an example JSON file?
