I am trying to do a load analysis for a project and couldnt find information on how much current with the lantronix ethernet module the 8 channel relay (ZADR830PROXR) draws.
Please plan a power budget of 200mA standby current and 100mA for each active relay. This should get you reasonably close. The actual current draw will be less, but surges are required for initial activation of relays. Once relays have stabilized, they draw around 65mA each. Please let us know if you need anything else.
Thank you Ryan.
If I plan on using the AD inputs I would have to add the current for whatever I am measuring correct? Or is this already included in the stand by mode?
The A/D input current will be minimal and is included in the standby power budget.
Please let me know if I can help you further.
