It is not clear the steps of how to get the waveform data from vibration sensor and parsing it.
Please somebody could help with it?
It will depend on the mode of operation.
If you are using the sensor in raw mode, then it will always send raw time domain data
if you are using the raw on-request mode, then you will need to send a command right after you receive the regular data message. This command can be found in the product manual.
it works like this
Bhaskar
Thanks, that help with little part of the problem. The other part is how to do the parsing of the data receiving, I tried to find the info in the manual, but I couldn’t.
Bhaskar
Any update of how to to parsing of raw data? It doesn’t show in the manual and my cristal ball is broken
Go to the product manual and look for the raw data table. You should find your cristal ball there
OK, I can see now. Thanks
