Yes, it’s possible, although I would not say it is simple. I assume you’ll be pulling the XBee module out of the gateway and directly applying data from another device in place of the XBee. All data comes in through the XBee socket Rx/Tx lines. Google XBee pinout and you can find where those connections are. Keep in mind you also need to connect to the GND pin to send RS 232 data to the XBee socket. We utilize the DigiMesh protocol on the XBee module. You’ll need to look up the documentation for the 900HP Digi module and find the section on Receive packet. This packet structure will need to be replicated by your “spoof” device. Also you’ll need to replicate the payload generated by our wireless sensors which is documented on the product pages under resources.
I posted another thread related to my gateway dropping connection, and I depending upon your answer to the follow-up question I provided, I may need to add some additional smarts to my driver.
Is there a start-up sequence I would need to send to the ESP32 from the XBee driver before I start sending packet data?
