I am looking to use a Taralist Time Activated Relay with 1 relay to trigger a Logo on a program channel for broadcast. Is this device capable of doing a timed event every hour on the hour repeating forever? Also, can you program how long the relay is closed for?
Taralist should be able to manage this, you will need to setup one event to activate the relay and another event to deactivate the relay each hour. So you should be able to do this with 48 events. You do not want to select the options to match day, month, or year. Hope this helps.
