GPIO inappropriately returning 1's
OK folks, I have a SPDT Relay Shield (https://store.ncd.io/product/iot-1-channel-spdt-relay-shield-7-gpio/) that I have been using to monitor the status of a float switch in a large water storage tank. The float switch opens or closes as a function of water level, i.e. it provides contact closure. Firmware running on an attached Particle Photon 2 queries - every 10 minutes - the status of GPIO-3 to which the float switch is attached and sends a 1 or a 0 to a pump in a well to turn it on or off accordingly.
I recently added an option to manually query the status of the GPIO-3 using a Particle.variable command in firmware. Even with the tank completely full and the circuit attached to GPIO-3 fully open, the query of GPIO-3 will occasionally return a ‘1’ for the briefest of times. Unfortunately, this will on rare occasion result in the pump coming on for 10 minutes when it otherwise should be off.
I have attached a screenshot of my Google Sheets log of events. The 1’s that appear therein are the 10 minute transmissions that correspond to the GPIO-3 queries (note that there was a forced Photon restart a 7:01 that was responsible for the ‘1’ at that time).
Any thoughts as to what is causing those mysterious readings?
Which library are you using to communicate with the MCP23008 IC on the board?
The only included library, Travis, is: #include <NCD2Relay.h>
Interestingly, the problem has disappeared. FM. So we can forget this (unless it reappears).
Lol. Ok Brian. Keep me updated and let me know if it rears it’s ugly head again.
