I have a Ethernet to I2C Converter which I configure the static IP using NCD config tool.
I can ping the device and this is fine.
I have a 8 channel relay card connected.
I can control my device in alpha station - i cab toggle relay and with the LEDs go on and off as connected but in base station the device Id fails and I have no connectivity even though the device is discovered. Using the API in LabVIEW I can also connect to the device but cant communicate with the rlay card.
I 'm currently connected directly to my laptop but I have also tried a switch and see the same results.
I’ve seen posts recommending using a router - does anyone have instruction for connecting to a router and i a router a must?
