Using a Fusion 48 Relay board with Web-i module, i can access the web page successfully both locally and remotely to configure and turn relays on and off. However, when toggling a relay to the “ON” state the page does not refresh indicating an “ON” state. I have to hit the refresh button for it to change. When “OFF” is selected the state is refreshed automatically. Am I missing a config setting somewhere?
Can you confirm that the Web-i is configured for the Fusion command set? This option is in the same area as where you set your home screen.
Yes, it is set for “Fusion - Reactor, Taralist, and ProXR Combined”
