We are using a Fusion 16 relay board FLL-FXR161DPDT that has two Ethernet ports. Each Ethernet module has the same IP address but they are on different networks. The status of all 16 relays is requested periodically on both networks. We also send commands to open or close specific relays at times, but the same command is never sent on both networks. The only common message on both networks is requesting relay status.
We are seeing the relay board unexpectedly change the state of the relays to what looks like All On to All Off once in a while. I’m wondering if both networks request relay status at the same time if there could be a potential problem. Is there any other thing that could cause this unexpected behavior? Thanks
