Are the Fusion Panels able to interface with Node Red? Is there a comparable tutorial available? I want to be able to create a dashboard to read some temperature sensors and contact closures on about 8 different Fusion boards.
We are still expanding our compatibility with Node-Red. At the moment we do not have support or tutorials for Fusion. However Fusion supports the full ProXR command set for controlling relays, we are working to add support for ProXR so that should be available later this year.
Long story short, currently no we do not have support. That said if you have a little tech savvy it is very possible to do this yourself. Node-Red has extensive documentation and the Fusion board is essentially a very simple device. Using the Fusion documentation one could have it working with Node-Red within a day or two.
