Are there any vibration sensing products that generate an on-board FFT? If so, are any of these compatible with the MQTT gateway?
this product supports time domain data which can be used for fft analysis.
Our MQTT gateway does not support time domain data analysis. I will recommend using a USB modem and a PC to perform fft analysis.
are there any plans in the future to add time domain waveform with the MQTT gateway?
