I purchased a feather adapter to permit the connection of a Particle Boron to my NCD relay board. Can someone tell me if the orientation of the feather adapter is correct in the attached photo (it can be plugged in in either direction)? Also, can I correctly assume that the relay board will continue to provide power to anything plugged into the feather adapter?
Yes, you have it installed correctly.
The board will supply power to the module installed in the Feather adapter.
