Ethernet Relay is Unresponsive
I recently purchased the Industrial Relay Controller 4-Channel DPDT + 8-Channel ADC with the NCD5500 Ethernet to Serial Module.
- ZUXPR45DPDTPROXR_PLUGGABLE
- NCD5500
I have an identical board with the same IP address and am using it with a custom program using the NCDComponent.dll. I configured both Ethernet to Serial modules to the same settings. The board I started with runs fine and the relays turn off and on on command.
The second board does not respond to any of the commands. I’m able to connect to it with BASE Station but when I select it, BASE Station just says “Device Identification Failed”. The indicator lights light up on RDY and BSY but nothing happens.
I exchanged the Ethernet to Serial modules and experienced the same issue. Could you help me fix this issue?
