I know the Static IP address on the Gen 3 ethernet module is fixed and hard coded on the hardware itself. Is there anyway I can pick a static IP address for my ethernet module?
Remote Control Fobs
Remote control fobs are a wireless/radio transmitter remote where you are able to control your applications with a push of a button by connecting to the receiver relays. These remotes can have up to 8 buttons/channels that you can operate with and have a variety of ranges allowing you to use these remotes from distances.
You can have wireless, Bluetooth or radio transmitter remote control systems. Once you have connected the remote control fob to these connection/receiver then your remote will work with whatever functions you need for your application.
