sufyan
#1
I’m currently using this sensor: Enterprise Wireless Sensor
When I try the Labview Utility from here: Enterprise Wireless Vibration and Temperature Sensor with Time series.exe
I keep getting an error when reading all the sensor configuration data as shown below:
Please assist, thank you!
Bhaskar
#2
is the sensor in confg mode?
Sensor needs to be in config mode in order to read and write the config settings.
sufyan
#3
Ahh, yes you are right. I did not set the sensor to config mode. Thank you!
