I have the enterprise gateway,EG5120-C2FCZ-4L-A06GL, and trying to setup the network configuration so that it will fail over from cellular to wifi or vica versa.
I see the button to switch between cellular networks but nothing between wifi/cellular
This is handled by the order of the list under Network > WAN. You can drag and drop the items in the list using the 6 dot icon. The higher on the list, the higher the Gateway will prioritize that internet connection.
awesome, thanks for confirming!
