Hi, we want to buy the following item
"Industrial Current Monitor 1-Channel 10-100 Max Amps Wired Split Core Dual Interface"
and use it to monitor a circuit that will be pulling less than 5 AMP (it is a set of table lamps)
will this product be able to monitor that circuit?
Yes, this will be able to monitor less them 5Amp. You can easily monitor down to couple of hundred milli amp.
Let me know if you have any other question.
Thank you very much!
