Is it possible to place a Particle Photon on the Screw Terminal Electron board with power supply? I woulx like to develop some apps before committing to usong Electron cellular data. The pins look correct as long as I place the Photon in the correct offset location.
The bottom pins should be the same (non chamfered ends). I have used several electron relay boards with photons.
You can double check the pin layouts on particle io Datasheets
edit: Also found under resources, see upper right side corner.
