Hello everyone
I set up my Edge and everything was working fine. Then i decided to put it on another WiFi network which i have. I changed the WiFi setting without having the Ethernet connected or selected to be on in the network settings. Now the WiFi indicates Down and ETH is blank. i cant access the edge page. any suggestions?
FYI …I have turned off and on the Edge and have it connected with the Ethernet cable.
Solution:
Initial problem was caused by disabling Ethernet.
You can gen into edge with its own Wi-Fi and change all the basic settings that you need! no need to reinstall the factory settings to get back in.
