Hi everyone!
I am working on a device which gets hooked onto a drone and consists of a raspberry pi zero and an LTE Hat. This device should be equipped with sensors like gyro and barometer. Therefore I am planning to use one of your i2c hats ( I2C Shield for Raspberry Pi Zero with Outward Facing I2C Port - store.ncd.io) to connect all needed sensors.
But, I am worried that all the interference coming from the drone motors / ESCs and LTE communication may break the I2C bus completely.
Is there anything you can suggest to avoid that ? E.g. shielded cables or sth. ?
Best Regards
Jan
