I am currently constructing a digital twin of an office space on the Azure platform and am now in the process of purchasing hardware. I am looking to capture the following data: temperature, humidity, lighting (if off/on and power consumption), water use (off/on and gallons used), and HVAC monitoring.
I am looking thus far at purchasing the “IoT Long Range Wireless Environmental Temperature Humidity Pressure Air Quality Sensor” as well as the “Azure Gateway - Wi-Fi Micro Gateway” but cannot find devices to capture lighting, water, and HVAC needs.
I have two questions-
1: Do you sell devices that can capture the data fields above?
2: If not, can other manufacturers devices connect to the Azure Gateway device? Would you recommend any particular devices or sellers?
