I have a question about this product:
Is it possible to connect Electromagnets (Holding solenoids) to output to regulate the voltage supplied to each Solenoid?
I need to connect 10 solenoids and change the voltage between 3-24V for each (to get different EM strengths). Each solenoid is 24v DC and 20W max.
The voltage should be controlled via Raspberry Pi 3b+ Touchscreen and GUI.
Is this product suitable for this purpose? If not, can you suggest me some other solution?
Thank you.
