I just purchased two of the ADC121C_ACS714_1Channel_Dc_Current_Monitoring_Sensor from NCD. I’m using Raspberry Pi and this library to read the current.
However, I’m getting 2.054A when even there is no current to read. I see the problem on both sensors so I don’t think its a bad component. I read Register 0, which according to the spec holds the latest ADC conversion value, and I get 0x806. Shouldn’t this register be zero when there is no circuit being sensed?
Is there any calibration I need to do beforehand?
This is a bi directional current sensor and when no current is flowing it will read 2.048V.
The reason behind is that while current flow from one directional to another the value will go from 2.048V to 5V and if the current directional changes the values will go from 2.048V to 0.
Thanks for the quick reply.
Ok. How do you then convert the value from Voltage to Current? For example, if I’m getting 2.078V reading. How do I convert that to current?
Amps = (Volt * 1000 - 2500)/185
in your case if the volt is 2.078V
Amp = (2.078 * 1000 - 2500)/185
Amp = 2.28A
The equation doesnt make sense to me.
If there is no current flowing, the value on register 0 will be 0x800 which translates to 2.048V. Is that right?
Then, to convert this to Amperage, we use your equation: Amps = (Volt*1000-2500)/185
If I plug in 2.048V into that equation, I get a non zero value (-2.44A) even though there is no current flowing. Is there something else I’m missing?
Amps = (2.048*1000-2500)/185 = -2.44A
the equation is assuming that your vref/vdd is 5V.
if no current is flowing and your Vout = 2.048 then then 2500 value will be replaced by 2.48
Are you saying that, if there is no current, the equation becomes Amps = (Volt * 1000 - 2.48)/185
That doesn’t look right. Did you mean Amps = (Volt * 1000 - 2048)/185
Is there a python script or example that I can use to automate the calculation?
my bad.Yes, 2048.
The equation looks like this
current = (voltage - vref)*sensitivity
in this case sensitivity = 183
Is there a way to increase sensitivity?
Why is the sensitivty 183? The spec sheets for ACS714 list out a number of sensitivites, including 185, but not 183.
