I plan to use these counters in a manufacturing scenario to record press stroke counts, for example. Can you suggest a simple workbench test scenario that should consistently produce a sensor count?
you can use a relay.
Yes but what are the specs on the input to the PR52-3B to register a count?
This device expects a contact closer input.
