I have seen the different apps that open on an android device to allow you to control relays by Bluetooth. What I need to know is if there is a way to tie that functionality into a website.
Here is my application.
I am setting up a kiosk on an Android Tablet running OS 4.4.4.1. It will lock in a website. On that website, the user has 6 large squares they can click, each containing a graphic. When they click a square it zooms in full screen and starts playing an mp3 file.
What I need, is a way to tell each of 6 relays to lock on when the mp3 starts playing and shut off when it ends.
This will allow us to let a light shine on the object we are talking about to highlight it for the user while the audio file is being played.
So I would have to add some code (Of which I am not sure) to the site that basically says while 01.mp3 is playing, turn on relay 1. while 02.mp3 is playing, turn on relay 2, and so on. If no mp3 is playing, all relays off.
The webpage already makes sure that only one mp3 can play at the same time.
Can this be done with your product or do you know of a way to achieve this?
Bob
