So I could reproduce this using one board and constantly opening and closing the socket to it and writing commands. I believe it has to do with the unexpected way python/linux handles socket.recv. It uses an algorithm to determine if the stream is done from what I can gather. So I altered the library to hard code a bytes expected back.
import time
class Relay_Controller:
def __init__(self, combus, kwargs = {}):
self.__dict__.update(kwargs)
self.renew_replace_interface(combus)
def set_relay_bank_status(self, status, bank = 1):
command = self.wrap_in_api([254, 140, status, bank])
return self.process_control_command_return(self.send_command(command, 4))
def toggle_relay_by_index(self, relay):
lsb = relay-1 & 255
msb = relay >> 8
command = self.wrap_in_api([254, 47, lsb, msb, 1])
def turn_on_relay_by_index(self, relay):
lsb = relay-1 & 255
msb = relay >> 8
command = self.wrap_in_api([254,48,lsb,msb])
def turn_off_relay_by_index(self, relay):
lsb = relay-1 & 255
msb = relay >> 8
command = self.wrap_in_api([254,47,lsb,msb])
def turn_off_relay_group(self, relay, bank, group_size):
command = self.wrap_in_api([254, 99+relay, bank, group_size-1])
def turn_on_relay_group(self, relay, bank, group_size):
command = self.wrap_in_api([254, 107+relay, bank, group_size-1])
def turn_on_relay_by_bank(self, relay, bank = 1):
command = self.wrap_in_api([254, 107+relay, bank])
def turn_off_relay_by_bank(self, relay, bank = 1):
command = self.wrap_in_api([254, 99+relay, bank])
def turn_on_relay_flasher(self, flasher, speed=1):
command = self.wrap_in_api([254, 45, flasher, speed])
def turn_off_relay_flasher(self, flasher):
command = self.wrap_in_api([254, 45, flasher, 0])
def set_flasher_speed(self, speed):
command = self.wrap_in_api([254, 45, 0, speed])
def start_relay_timer(self, timer, hours, minutes, seconds, relay):
command = self.wrap_in_api([254, 50, 49+timer, hours, minutes, seconds, relay-1])
def get_relay_bank_status(self, bank = 1):
command = self.wrap_in_api([254,124, bank])
return self.process_read_command_return(self.send_command(command, 4))
def get_relay_status_by_index(self, relay):
lsb = relay-1 & 255
msb = relay >> 8
command = self.wrap_in_api([254, 44, lsb, msb])
def get_relay_status_by_index_fusion(self, relay):
lsb = relay-1 & 255
msb = relay >> 8
command = self.wrap_in_api([254, 144, lsb, msb])
def read_single_ad8(self, channel):
#TODO read back single integer
command = self.wrap_in_api([254, 149+channel])
return self.translate_ad(self.process_read_command_return(self.send_command(command, 4)), 8)
def read_all_ad8(self):
command = self.wrap_in_api([254, 166])
return self.translate_ad(self.process_read_command_return(self.send_command(command, 11)), 8)
def read_single_ad10(self, channel):
command = self.wrap_in_api([254, 157+channel])
return self.translate_ad(self.process_read_command_return(self.send_command(command, 5)), 10)
def read_all_ad10(self):
command = self.wrap_in_api([254, 167])
return self.translate_ad(self.process_read_command_return(self.send_command(command, 19)), 10)
def get_relay_status_by_bank(self, relay, bank = 1):
command = self.wrap_in_api([254,115+relay, bank])
def convert_data(self, data):
command_string = ''
for character in data:
command_string += chr(character)
return command_string
def add_checksum(self, data):
data.append(int(sum(data) & 255))
return data
def wrap_in_api(self, data):
bytes_in_packet = len(data)
data.insert(0, bytes_in_packet)
data.insert(0, 170)
data = self.add_checksum(data)
return data
def send_command(self, command, bytes_back):
# The following line is causing problems and has been commented out until further study.
command = self.convert_data(command)
if self.combus_type == 'serial':
self.combus.write(command)
return self.combus.read(bytes_back)
else:
self.combus.send(command)
recvBuffer = ""
timeStart = int(round(time.time() * 1000))
while (len(recvBuffer) < bytes_back):
recvBuffer += self.combus.recv(bytes_back)
if timeStart < (int(round(time.time() * 1000)) - (self.combus.gettimeout() * 1000)):
raise ValueError('The device did not return the expected number of bytes.')
continue
return recvBuffer
def process_control_command_return(self, data):
handshake = self.check_handshake(data)
bytes_back = self.check_bytes_back(data)
checksum = self.check_checksum(data)
if handshake and bytes_back and checksum:
return True
else:
return False
def process_read_command_return(self, data):
return self.get_payload(data)
else:
return False
def get_payload(self, data):
payload = []
for byte in range(2, len(data)-1):
payload.append(ord(data[byte:byte+1]))
return payload
def check_handshake(self, data):
return ord(data[:1]) == 170
def check_bytes_back(self, data):
return ord(data[1:2]) == (len(data)-3)
def check_checksum(self,data):
dlength = len(data)
dsum = 0
for byte in range(0, dlength-1):
dsum += (ord(data[byte:byte+1]))
return dsum & 255 == ord(data[dlength-1:dlength])
def translate_ad(self, data, resolution):
read_array = []
if resolution == 10:
for index in range(0, len(data), 2):
read_array.append(((data[index] & 3) << 8) + data[index+1])
return read_array
elif resolution == 8:
return data
return False
def renew_replace_interface(self, combus):
self.combus = combus
if 'serial' in str(type(self.combus)):
self.combus_type = 'serial'
else:
self.combus_type = 'socket'
