I’ve successfuly setup a single contact closure board with WIFI push notification to email using N-Button Lite. Is there a way to send the email with the board itself? or an additional board with out a PC on the LAN?
You could use one of our IFTTT compatible boards with the IFTTT service. Boards: https://store.ncd.io/shop/?fwp_series=ifttt
Or you could use an Arduino, Raspberry Pi, Photon, etc. to write on-board code for one of our I2C boards.
Hi, what kind of board do you have?
If your board has wifi connectivity, you could code in it http calls to programs like Pushbullet or Pusher and send yourself a notification like explained here:
