I was able to flash the gateway, but I started getting this error:
"problem": "Failed to fetch device list",
"message": {
"message": "Failed to parse JSON",
"err": {
"line": 38,
"column": 44,
"sourceURL": "http://captive.apple.com/main.js"
"data": {
"discovered_devices": {
"00:13:A2:00:41:A8:44:01": {
"transmission_count": 241,
"battery_level": "99%",
"node_id": 1,
"rssi": "100%",
"Channel 1": 19,
"Channel 2": 18.93,
"Channel 3": 16.37,
"mac": "00:13:A2:00:41:A8:44:01"
"configured_devices": {}
"message": {
"err": {
"line": 38,
"column": 44,
"data": {
"transmission_count": 243,
"node_id": 1,
"rssi": "100%",
"Channel 1": 19,
"Channel 2": 18.81,
"Channel 3": 15.68,
"message": {
"err": {
"line": 38,
"column": 44,
"data": {
"transmission_count": 244,
"node_id": 1,
"rssi": "100%",
"Channel 1": 19,
"Channel 2": 18.81,
"Channel 3": 16.31,
"message": {
"err": {
"line": 38,
"column": 44,
"data": {
"transmission_count": 245,
"node_id": 1,
"rssi": "100%",
"Channel 1": 19,
"Channel 2": 18.81,
"Channel 3": 15.12,
"message": {
"err": {
"line": 38,
"column": 44,
"data": {
"transmission_count": 247,
"node_id": 1,
"rssi": "100%",
"Channel 1": 18.93,
"Channel 2": 18.81,
"Channel 3": 15.12,
