I am using 2 KeyFobs with 2 KFX boards. My idea is to have each key fob control one KFX device and not both. I did the learning for both keyfobs, but the keyfobs are getting detected by both of the KFX devices. I assume that this is due to the fact that the address of the Keyfobs are not unique. So i opened the keyfob and tried opening the address lines(A0 to A9) to see if I can make those unique. But the result is still the same. Am I missing something here or is there no possibility that the KFX can distinguish between two keyfobs based on the address line configuration.
Many Thanks,
Tony
