If the encryption key, encryption enable, network ID, and preamble ID are all the same then you should see the data from the sensor on the receiver.
You won’t be able to send data to the sensor while it is in RUN mode because it will be asleep.
Okay so I put the receiver in config mode (setting the network ID to 0x7BCD), then put the sensor I want to configure in configuration mode by doing a factory reset. Then I write specific values to encryption key and network ID using that file. Then I click the reset to put the sensor back into run mode because now I want to start receiving sensor data from the sensor. I then switch the network ID and the encryption key on my receiver to the same specific values I set on the sensor. I should be able to see the data from the sensor on the receiver? I have not changed the encryption enable (seems like it is always 1/True) and the preamble ID on either device.
Are you able to see the sensor on the receiver after you’ve changed the encryption key and the network ID?
Best,
Ida
This is the Jacob above, I’m out of the office due to inclement weather.
Yes, the library and example code I wrote alters my sensor’s settings properly and I can receive data from it after a reset.
I don’t see anything wrong with your code, but I had to work around some strangeness with how the digi library handles serial ports in the library. It doesn’t sound like you’re running into that.
Can you try the library and example code and see if that works? Just run the example config with the proper modem settings and put the sensor in config mode. It will automatically write the settings.
You might also try a factory reset on the device, hold config, press release, release config after ~15 seconds. It will boot up in PGM mode automatically once it has reset.
Okay tried it and this is what I see in terminal
full return: {'nodeId': 0, 'sensor_type': 4, 'mode': 'PGM', 'source_address': '0013A200418E9E29'}
nodeId 0
sensor_type 4
mode PGM
source_address 0013A200418E9E29
send address
full return: {'nodeId': 0, 'counter': 1, 'mode': False, 'sensor_type': 4, 'source_address': '0013A200418E9E29', 'config_response': bytearray(b'\x00\x02X\x00\x00\x00\x00\x00\x00')}
nodeId 0
counter 1
mode False
sensor_type 4
config_response bytearray(b'\x00\x02X\x00\x00\x00\x00\x00\x00')
full return: {'nodeId': 167, 'sensor_type': 4, 'error': 10, 'mode': False, 'error_message': 'Invalid/Incomplete Packet Received'}
nodeId 167
sensor_type 4
error 10
mode False
error_message Invalid/Incomplete Packet Received
Can you replace the set node id and sleep duration line to this: ncdModem.send_data_to_address(sensor_data[‘source_address’], bytearray.fromhex(‘f702000000a70001a2’))
and see if that fixes that error?
@jacob that doesn’t seem to fix it
Here is what I am seeing/
Admins-MacBook-Pro:NCDEnterpise-Python-dev idahuang$ python EnterpriseNCD-Configuration-Example.py
full return: {'nodeId': 167, 'sensor_type': 4, 'mode': 'PGM', 'source_address': '0013A2004191540C'}
nodeId 167
sensor_type 4
mode PGM
source_address 0013A2004191540C
in config
read sleep duration
set node id
send address
full return: {'nodeId': 167, 'counter': 1, 'mode': False, 'sensor_type': 4, 'source_address': '0013A2004191540C', 'config_response': bytearray(b'\x00\x01\xa2\x00\x00\x00\x00\x00\x00')}
nodeId 167
counter 1
mode False
sensor_type 4
config_response bytearray(b'\x00\x01\xa2\x00\x00\x00\x00\x00\x00')
nodeId 167
sensor_type 4
error 10
mode False
I think the packet is slightly off.
I sent this which is in your example file
ncdModem.send_data_to_address(sensor_data['source_address'], bytearray.fromhex('F7020000000100012C'))
/dev/cu.usbserial-AC4609Q2SENT OperatingMode.API_MODE7E 00 17 10 10 00 13 A2 00 41 91 54 0C FF FE 00 00 F7 02 00 00 00 01 00 01 2C D4
There is an 10 from the frame id instead of 0?
Also why do you call this and open and close the device?
def ncd_xbee_serial_open_override(self):
self.device.close()
self.device.open()
self.device.add_packet_received_callback(self.parse)
The digi library was holding the serial port without giving me access to it during a listener callback. It was the issue I was having with their library.
