I’m replacing the battery in a Gen4 Vibration Sensor using the 3.3V D-cell supercap replacement battery. When I removed the original battery, I noticed it was held in place with adhesive on the bottom and side.
Should the new battery also be secured with adhesive? I’m concerned that a loose battery could rattle inside the enclosure and affect the vibration readings. If adhesive is recommended, is there a specific product you suggest (e.g., a particular double-sided tape or RTV silicone)?
Thanks in advance!
