I have downloaded the base program but it cant seem to find the proper baud rate. i set it at 115200 along with several others and it wont connect. It does its own scan and cant connect either.
If Base Station is cycling through baud rates it means it’s not able to communicate with the controller. Can you tell me what controller you have? You can provide an image of the board as well if you like, sometimes that’s best.
XBee S3B. This is piggybacked on a zigmo2. It was my understanding that this is the method of programming the xbee then I will put it on my zuxpr2 control board.
