Hi. Here’s the case. Recently I purchased a Wireless 4-20mA 4-Channel Input endNode.
Follow the instructions here
Everything is good, unlike my previous trial in link
I am using the same sensor which has been tested okay with 2 Channel Industrial IoT Long Range Wireless 4-20mA Current Receiver link
Wireless section is okay as well.
I am interested to know what would happen/is the purpose if the ‘Set Gain to 1 (4-40mA)’ is checked?
Is it possible to add support to Azure gateway so Device Twin could show the data as well?
From the map, I can’t find PR53-6 and PR53-7 at all.
If I do need the Azure back up, does it mean I could only use 2 channel wireless current receiver? -
If I want to further try to use nodeLynk to add Relay Controllers, Sensors etc.? Is there any easy tool like Alpha Station to view the data or I can ONLY send hex command and parse the hex return to know the readings with reference of API Calculator?
Is there any material good for python user to take reference (class, function etc to open port, send and receive commands)?
