I have a micro gateway (PR55-21 MQTT) that was flashed to be an azure gateway and a Temp/Humid sensor (PR49-24G) that I am trying to connect. Order Number: #385663
I have been able to connect the gateway and Azure but when I look in the device twin I do not have a nodes object as described in the quick start guide. When set the gateway to config mode and connect to it there are no devices in the devices tab.
However if I turn on config mode and set the sensor to config mode I can get a Mac address to show up (See attached screenshot)
Even then I do not get any of the other data in any of the columns and nothing in my device twin, nor am I getting and Device to Cloud messages.
I have tried this setup with the antennae unplugged and close to each other, unplugged and across the room (14 feet or so), antennae plugged in and close to each other, plugged in and across the room. They all have the same results.
Is there anything else I am missing?
Marc
