Avg mA draw @12vdc? of Web 2 Ch SSR DC 3amp
Hello, can you please estimate for:
Solid State Relay Controller 2-Channel + 8 Channel ADC ProXR Lite
  • paired with Type F relays & ethernet control module
Thanks.
Standby current draw @12VDC should be less than 200mA. Energized relays will draw additional current as outlined in the data sheet for the relays available here: https://ncd.io/solid-state-relay-types/
