Hi, I recently purchased an AMS 5915-1000-A for a project. When I go to test the sensor with the given AMS5915_1000_A example sketch for arduino, I get a baseline pressure of around 843 mbar without applying any pressure. The range I need (i.e. 0 - 65mbar) is a quite a bit smaller than the overall range of the sensor, but I was informed that it would be accurate enough for this regardless. Is there some way I can calibrate the sensor to 0 mbar when no pressure is applied?
Hello!
Iām from India & currently studying in Second Year of Mechanical Engineering.
My question is, how do I measure the Hydrostatic Pressure with this Sensor (AMS5812)?
Can it just be done by dipping an hose into the water? And how the water will travel through the pipe & reach the sensor port?
