I purchased an AMS5812-0000-D-B and AMS5812-0008-D-B. The 0008 worked like a charm in Node-Red on a Raspberry Pi 4. However, the 0000 wasn’t working until I left the node configured for the 0008. I get an output between -1.000 and 0.999, so I’m assuming that is -100% to 100% of the sensors -5.17 to 5.17 mbar range and I can simply add a scale/range node.
Not a big deal, but wanted to put this out there in case anyone else has issues or you are working on a code update.
