While trying to get to 'Sensor View ‘, I received a pop-up error that says ’ unhandled exception has occurred in your application. If you click Continue, the application will ignore the error and attempt to continue. If you click Quit, the application will close immediately. Value of ‘127’ is not valid for ‘Value’. ‘Value’ should be between ‘Minimum’ and ‘Maximum’.’
Whenever I click Continue after this pop-up, I am unable to locate my acceleration impact detection module with the program.
I’m unsure of what I did to get to this error - any help would be appreciated.
did you try the Labview ui?
Yes, and the accelerometer is not showing up there either
is the sensor powered up?
The baud rate needs to set at 115200.
after opening the ui hit reset and it will send a data packet.
Please send a screen shot of the error if you can and we will try to reproduce the problem here.
