Hello ! , would you mind if you could help me to know which one ADC to I2C device model compatible with Particle Boron use for measuring at least 10/11 analog readings for 5 analog sensors(CO, SO2, NO2, O3, etc).
while placing the order mention this " build with 3.3V I2C logic"
keep in mind this will also reduce the ADC input voltage range from 5V to 3.3V.
or this board as power supply option. you can power it using 3.3v over the I2C port.
set the power jumper to bus and you can use the board with 3.3v without any modification.
