bstill
November 20, 2018, 7:15pm
#1
I just purchased AD5252 digital pots and the 12c <-> USC converter.
I try to connect to it via NCD Base and it says it cant find it.
If I use AnyI2C, it appears to connect to the com port (com 1) but I get write failures trying to communicate with the AD5252’s.
I am in windows 7.
I have 3 AD5252’s and I have given each a unique address.
Any help communicating with the device would be great!
Bhaskar
November 20, 2018, 8:46pm
#2
Does the board show up when run the i2c scan?
Make sure you are using the correct i2c address in the UI.
bstill
November 21, 2018, 3:34pm
#3
I do Open the connection withthe default settings and it says connection opened.
When I do the Scan I2C Devices button, it comes back with nothing.
How do I know what the address is?
That all being said, I think i might have an issue with the virtual com ports… I see the Serial Converter, but I dont see any com ports created for this.
Bhaskar
November 21, 2018, 4:10pm
#4
this might be related to ftdi driver in that case.
does the com port shows up in the device manager ?
bstill
November 21, 2018, 4:29pm
#5
I tried to update the driver and it said it was up to date, I downloaded the latest from ftdichip dot com.
I see only com 1 only which is there regardless if i have the hardware plugged in or not. I dont see any other com ports present in device manager.
Bhaskar
November 21, 2018, 4:32pm
#6
this guide might help in troubleshooting
bstill
November 21, 2018, 4:59pm
#7
Yea, I saw that yesterday. It doesnt help.
I am on win 7…
Bhaskar
November 21, 2018, 5:01pm
#8
do you happen to have any other PC you can use for testing?
bstill
November 21, 2018, 5:43pm
#9
I just tried it on another PC I just happened to have at my desk that is non-corporate… and it worked… guess corporate policy wins again grrr…
