Hi, I am using MQTT gateway and in my case the Gateway will be at the remote site. Gateway will be connected to my MQTT broker server to publish sensor data. Is there any possibility/way to access and put the gateway in config mode remotely? This is required because its not convenient to go at site every time to put the gateway in config mode whenever we need to change the sensor configuration or add a new sensor to gateway.
Thankyou.
No, it is not possible to remotely put the Gateway into Config mode. It requires physical access. However it is rare that this is required after the Gateway is setup unless it needs to connect to a different broker or WiFi network(in which case remote access would not be possible anyway).
Not allowing remote configuration of the Gateway was intentional as it is an added security measure to prevent someone from intercepting the gateway’s data.
