Hello, I need help trying to figure out why my Standalone Industrial Vibration Temperature Sensor’s Acceleration Threshold isn’t working. It is set to 1 in Node Red so 50mg but testing it with various vibrations above that doesn’t trigger the threshold.
are you getting two packets back to back by any chance ?
if that’s the case it means the threshold i set too low. set its value to 5.
Once the sensor is triggered by exceeding the vibration threshold, how many minutes does it take for it to reset to send data the second time if the vibration threshold is exceeded again?
once the threshold is triggered it will send a packet and then go back to sleep till the reset of the sample interval.
once the threshold is triggered it wont keep sending data, that will drain the battery.
