Hi
I did bought “1-Channel Off-Board 98% Accuracy 100-Amp AC Current Monitor with IoT Interface”.
And when i started using it to check the current through several cable, all what i got is 0-ampere.
So, does this sensor work with regular cables, such as Universal Power Cord. ?
Also, is it okay to use a power source which provide 12VDC and 1Amp to the board ?
thanks
