I am having problems with the 4 channel 4-20mA receive module. Sometimes it works most of the time it doesn’t. Does anybody have experience with this module?. The I2C codes are sent as i confirmed with logic analyser but noting is being sent back from the MCP3428 IC. Could it be a conception problem as i don’t see no decoupling capacitor near the MCP3428. Any help would be greatly appreciated.
I use a i2c level shifter between master (Cortex M0) and slave (MCP3428) ,
the pull ups are ON on the 5V slave side but i have no pull ups on the 3.3V
master side of things. I tried to put some on the 3.3V side but no change.
The feather M0 from Adafruit is the master device that contains a ATSAMD21G18 Cortex M0 unit
and i think it is 5V tolerant (5V output with pull-ups) but need more investigation on that will post back.
Anyway i tried with direct connections and it didn’t work… i will try again.
